Antenna Bar
2 Answers 2 Score |
Keyboard and trackpad spare parts + replacement instructions |
2 Answers 0 Score |
Replacing the display on a MacBook Air M2 15" (A2941) |
1 Answer 0 Score |
Is it possible to replace the screen on the MacBook Air 15" A2941? |
1 Answer 0 Score |
MacBook Air will not power on |
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
A2941 EMC 8301 2024 Mac14,15 3.49 GHz M2 8-Core Processor/10-Core GPU/16-Core Neural Engine
Background
Introduced as the first 15-inch MacBook Air in Apple's lineup, the 2023 15" MacBook Air was announced at the WWDC and released shortly after in June 2023. It features a 15.3-inch display and an M2 SoC.
Starting at $1299, it's available in either Silver, Starlight, Space Gray, or Midnight.
Identification
Identified by model number A2941. Two USB-C ports and a MagSafe 3 port are on the left edge, and one headphone jack is on the right. The enclosure is machined aluminum with four protruding circular feet on the underside. The display has a notch, and a Touch-ID power button is located at the upper-righthand side of the keyboard.
Users can find help with identifying their MacBook Air laptops here.
Technical Specifications
Display
- 15.3" LED-backlit IPS panel with True Tone; 2880 x 1864 pixels (224 ppi); P3 wide color gamut; 500 nits
Processor
- Apple M2 3.5 GHz 8-core CPU, 16-core Neural Engine
Graphics
- Apple M2 integrated 10-core GPU
Storage
- 256 GB PCIe-based SSD, configurable to 512 GB, 1 TB, or 2 TB
Memory
- 8 GB of unified memory, configurable to 16 GB or 24 GB
Wireless
- 802.11ax Wi-Fi 6 wireless networking; IEEE 802.11a/b/g/n/ac compatible
- Bluetooth 5.3 wireless technology
Battery
- Built-in 66.5-watt-hour lithium-polymer battery
- Up to 15 hours of web browsing, up to 18 hours of video playback
Dimensions
- Height: 0.45 in (1.15 cm)
- Width: 13.40 in (34.04 cm)
- Depth: 9.35 in (23.76 cm)
- Weight: 3.3 lbs (1.51 kg)
Ports
- 1x MagSafe 3 magnetic charging port
- 2× Thunderbolt / USB 4 port (Thunderbolt 3, USB-C 3.1 Gen 2)
- 1× 3.5 mm headphone jack
